Power
HO Alt, 1/0 OFC welding cable, and replace your current battery (provided it's not tiny) with an AGM and you should be fine
I have a 160 Alt...I don't need an alt. I just need an extra battery. I'l just get a 700CA battery. I Have 0 gauge power and ground. I'm just adding as a precautionary measure.
You didn't mention the alt. Probably getting around 80a at idle so you should be ok especially with 1200w. 2-3kw is where I see people needing more upgrades
Shouldn’t need anything. If you have issues it’s you not the electrical. Clipping or bad ground.
My thoughs as well. A solid primary battery and "big 3" should be adequate to support that assuming your factory alternator is functioning.
Wtf?! moron. And this is coming from someone who can't build a wall.
Cars don't need batteries these day bro. They run off of electricity.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
522
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
389
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
800
SQBeast
SQBeast
Leesburg, Ga
nauc
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
