Fosgate Punch Stage 3 15" Help Plz
  • 1
PuMpDatBaSs420
E| (*.*)<~~SSS |3
Trying to figure out a good single amp setup for 2x RF Punch Stage 3 15" subs. Id rather get the dual 4 ohm's (mostly because they're $30 cheaper lol) but the dual 2 ohms are an option.
Amp shouldn't be more than $200 and should be able to throw them pretty hard, thinking those subs can take from 750-1000 watts daily(not too sure about that though.) But if anyone has any ideas for a good amp setup/more info Id greatly appreciate it.
Trying to put the subs in a 2.75 cube box tuned at 28-32 hz. Porbably going with 32 since i found box plans for one on here (stickys rox) but not sure how itll sound
before i get flamed too id just like to say im no expert at car audio but im trying to learn the ropes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
PuMpDatBaSs420
E| (*.*)<~~SSS |3
PuMpDatBaSs420
In a nutshell
PuMpDatBaSs420
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
