Worklog: 4 SX 15's wall setup in a Durango *Pics*
If you use photobucket, download irfanview from download.com and you can do pretty much anything you want with your images. I have used irfanview for years and it is great. Looks good by the way.
You can resize the pics in MSPAINT....
Image > Attributes... as long as you keep the same scale that the picture is taken in, and you enter both the values accordingly you can do it like that.
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif Been working a lot between 10 & 14 hours a day. Doesn't leave much time to work on the car.
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
NeverEnuffBass
Got Bass?
NeverEnuffBass
Greenwich, CT
80INCHES
