Wiring feedback - how can it be stopped?
  • 2
tntonelli
I have a BMW X3 and installed a DICE device to play my iPod. Over time, it has this incredible feedback, and I have returned the device once. I am convinced it is in the line/wires of the car not the device. I have added chokes onto the wires, but it does not do anything. Any suggestions? It is the manufacturing bundle of wires that was set up to hook up a CD changer in the car, so I did not rewire anything specifically, it is something that all BMWs use. I just feel that there is some way to fix this thing, but I am clueless on the electrical wiring options.
Thanks!
Thanks!
It's not "feedback". It is engine whine. It happens when you have a bad ground. That factory harness has an incredibly poor ground. Add a wire from the harness's ground to a paint free portion of the body.
Thanks for your reply. the wires are all bunched together to a clip that hooks to the device, is that easy to separate out the ground?
Everything is relative. If you have a color coded chart showing you which wire is which... yes it could be simple. If you have electronics experience and a digital multimeter then you could determine which is ground on your own. If none of the aforementioned describes you, it could be nearly impossible.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
326
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
407
503
455
tntonelli
tntonelli
Worcester, MA
ahole-ic
    May 24, 2024
    May 23, 2024
