wiring 2 dvc
Mercureie
Stay in S-C-H-O-O-L
i jus ordered 2 10 alpine type r's dvc, 300 rms. i'll be runnin em off a M286i, 300x1, from ma audio. now if i wire each sub in series with itself then parallel the two together will that give me a 2 ohm load? and what gauge wire should i use, if it matters?
Originally posted by Mercureie i jus ordered 2 10 alpine type r's dvc, 300 rms. i'll be runnin em off a M286i, 300x1, from ma audio. now if i wire each sub in series with itself then parallel the two together will that give me a 2 ohm load? and what gauge wire should i use, if it matters?
8awg wire should be fine, but you might wanna run 4awg just in case you decide to upgrade later.
are they dual 2 or dual 4 Ohm VCs?
Originally posted by drkodin 8awg wire should be fine, but you might wanna run 4awg just in case you decide to upgrade later.
8 and 4awg wire for a sub at a mear 300watts rms? Are you on crack? Try a 12-14awg wire and you will be more than fine. There is NO need to go any lower than that unless you are pushing MUCH more than 300watts (like30,000 and even then a 12awg is not a bad choice)
Originally posted by Alaxan 8 and 4awg wire for a sub at a mear 300watts rms? Are you on crack? Try a 12-14awg wire and you will be more than fine. There is NO need to go any lower than that unless you are pushing MUCH more than 300watts (like30,000 and even then a 12awg is not a bad choice)
wow, calm down dude. i see what you are talking about now, but i thought he meant power wire. i figured everyone pretty much knew that any speaker wire will work for any application.
Cant someone throw up a picture (windows paint program) or something of how to wire the 2 DVC's as original asked?
I just recieved my 2 pioneer DVC's yeseterday and want to install them in a similarly. Thanks.
here are your options.....im assuming you have 2ohm dvc subs....
series
parallel
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
377
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
296
488
Mercureie
Stay in S-C-H-O-O-L
Mercureie
Cleveland, OH
MikeofTulsa
    May 24, 2024
