Newbie: Cd Changer error code question
  • 3
nbp
ny
After fixing a loose connection to my car battery that was causing my speakers to cut out intermittently, my Eclipse 12 CD changer will not operate. Instead I get an "error 9" message. I get the same message if I change stations on the tuner but then the tuner works fine.
Being a novice to the audio world,I would appreciate any help I can get figuring out what this error code is and how to fix it. Thanks.
Neil
Originally posted by nbp After fixing a loose connection to my car battery that was causing my speakers to cut out intermittently, my Eclipse 12 CD changer will not operate. Instead I get an "error 9" message. I get the same message if I change stations on the tuner but then the tuner works fine.
Neil
You should check the documentation that came with your CD reciver, it should have a lsit of error codes, what they are caused by and how to fix them. Every company has a diffrent code system
Thanks for the reply. Unfortunately, I do not have the documentation for this Eclipse CD tuner. Is Eclipse still around?
Any other help would be greatly appreciated. Thanks.
Neil
Originally posted by nbp Thanks for the reply. Unfortunately, I do not have the documentation for this Eclipse CD tuner. Is Eclipse still around?
Neil
I have no idea if Eclpis is still around or not, i did a search for a web site for them and couldnt find one. YOu you happen to know the web site chekc there they shoudl have some kinda e mail addy to contact for help. SOrry i cant be more helpful.
Thanks for the replys. I sent an e-mail to the Eclipse tech address. I'll let you know how it turns out.
Neil
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
758
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
Wow. That's a nice truck. Where I live there are few cars and trucks that use only one amplifier to power the speakers. So already noticeable...
6
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
nbp
nbp
ny
nbp
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
