why are my sub cutting out
ok i feel like doing something today i have nothing to do so im going to rewire them
the guy said i should do it like this
so my subs dont have 2 pos and 2 neg connectors on each sub its only 1 neg and 1 pos so how do i do it like that pic
so is all i do is leave it how it is i just add a piece of wire to each sub going from the pos to neg connector
think of each sub in the picture as a pair, thats 2 subs... wire each pair of subs together from the positive on one sub to the negative on the other, so on and so forth its a little bit of work, but what did you expect with 6 subs...
also asking someone to post a diagram isnt needed, you have a perfectly good example, which if you cant understand you shoulld probably not be messing with it... i suggest you try to do a little bit of research i know you may not have alot of time, but read up educate yourself so that you dont have to learn the expensive way, your current setup with your subs wired te way they are could kill your amp or damage your speakers
the diagram is for dvc mine are svc
yea i mested it up i put like positive to negative not from one sub to another but just on the same sub then no bass played so i just put it back like i had it
so ill just get a .5 stable amp
markak134
Banned
markak134
pa
Drek75633
