when sub hits hard the head unit shuts off
My guess would be that when the bass hits, it causes a voltage drop on your electrical system. This in turn causes the HU to receive less voltage than it needs to operate properly, so it's "forced" to shut off till the voltage rises again.
Do your lights or anything dim when the bass hits real hard?
Well, first we need to verify that this is indeed the problem //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Do your lights or anything dim when you have the volume up high? Do you have a voltage meter in your vehicle? If so, how low does the voltage drop?
i dont have a voltage meter but the head lughts do not dim or the iterior gauge panel lights i checked all of my connections the other day they are solid with gold audio connectors
yeah..like 4 guage....and platinum connectors...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Please don't //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
why not?? huh?? who the falk died and made u an audio god?? huh? who???
bastages running around thinking they know it all...sheesh...
the 4 guage mighta worked...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
see^^^
4 guage fo hu power =t3h win!!!
big power hu's need big power wire...duhhhhh
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
If your lights do not dim and the amp itself does not shut down I wouldn't think you are losing enough voltage to shut down your head unit. Is it possible that you have a loose connection on your head unit? I second the WTF would you run 4 gauge to a head unit for sentiment. Head units simply do not need that kind of current. Even if it were going to do any good you would have to run a 4 gauge ground also to be effective.
volcom666dj
volcom666dj
lacey
volcom666dj
