what sub to go with?
ShinyC10
So I drive a 1986 c10 with the bench seat and two cheap mb quart 10" shadow mounts behind it running of a sound stream ta1.600d amp. This summer I'm planning on swapping out the bench with buckets, build a console from the dashto theback of the cab and put a sub in the back of the console. I'll be removing the two 10" subs once the seats are swapped. What will be a good sub for this amp that I can put in the console? Limitis around 100-150 for sub. And the head unit is a retro sound model two.
ShinyC10
ShinyC10
Houston, Tx
ShinyC10
michigan born
    May 14, 2026
michigan born
    May 14, 2026
