what should i look for ?
Not trying to be an a$$ or anything. But the best system you can ever hope to put together, is what sounds best to you. And fits your budget, and the space you have to work with. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
looks ok to me..but the amp/sub are not at all good quality. however, in this case i would say it's a good deal just b/c the price is so low
thanks ....... see i know nothing about amps/and subs what should i look for when buying one?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif.............. like does it matter what watts is it ? should i buy sub that have higher watts? and what does this mean? """2 Ohm Minimum Impedance "". im sorry for all the question,
thanks
np man, i can't really steer you in a direction towards subs, except that i would recommend one with a recommended running power of 600 or under, otherwise you might need an alternator upgrade or a cap. As far as amps, try to get one that comes as close as you can to the subwoofers recommended power. stay away from lanzar, legacy and pyle if at all possible.
The CT's are nice, That Sundown is a a frik'n beast!
714
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
630
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
717
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
king13028
king13028
nc
king13028
    May 18, 2024
    May 16, 2024
