What is going on with my sub?
im not trying to lessen my shame but your a dumbass. there is no way you would make a post like that with out reading what everyone already said.
edited
obviously you havent been here long, i know what happens to people like you, who make comments like that, it happens on every forum, did you get your computer as an early christmas gift?
But to the OP... the 15" CVR is hitting deeper than 2 12" L7s because 15's have lots of cone area and can really move the air to have a deeper sounding bass. That, and L7's aren't known for having the deepest hitting bass out there. They usually peak in the 40's
It has a lot to do with the enclosures too. If the enclosure for the l7s was a prefab, then it was probably tuned to about 40hz with very little port area and only 1.5 cubes per 12. That's not much room at all and tuned way too high to get anything low out of them.
im not trying to lessen my shame but your a dumbass. there is know way you would make a post like that with out reading what everyone already said.
but so far i feel that i have been semi proven wrong. i have been looking and only found that underpowering a sub well only blow if you have the amp pushed to hard. hence clipping it and causing damage.
im sorry i caused such a riot. i should have gone over my research before saying it rather then trying to remember it.
It fine, if thats what you thought was right then you were only trying to help inform everyone else as well. But as long as you can admit you could be wrong then your //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif with me.
edited
are you trying to make a point with that comment or is it pointless rambling.
are you trying to sympathize now or are you insulting me more? or just trying to sound cool?
(not to mention you "claim" to have not read everything? well if that is true then your no worse then i am. you saw half the information and made a conclussion and then tried to take a stab at me. i did the same thing. i read half of something and made a conclussion and took a stab at trying to help someone. my topic was just more touchy on this forum. and another difference is that my post was trying to help someone, prick.)
thank you
no i saw what you posted and then i responded to you, kthxbye
You have been proven semi-wrong?! You have been proven completely wrong. Dude, its ok, you were misinformed and made an idiotic post. Now learn from it and actually learn the truth of the matter, underpowering a sub WILL NOT blow the sub.
You just said if the amp is pushed too hard hence clipping, meaning it is sending out more power, unclean power, so its not the underpowering that will blow the sub, its the additional power thats not clean (clipped).
i said semi because it IS possible to blow a sub with an under powered amp. and i said nothing about perfect clean signal. my original comment very much simple. calm down
i know i was wrong by saying that is would cause over heating and burning up the coil by it. but my comment wasn't coming completely out of the blue.
i admidted i was wrong get over it. stop trying to hope on a train that has left the station bro. this thread is dead
Well the box wasn't a pre-fab it was custom ported to around 32-35hz. It was built to kickers specs for deep bass. The jbl 1200.1 amp I read was 1200 rms, so how would I be underpowering it by that much since both subs equal 1400 rms, and me giving it 1200 rms( Even heard the jbl amps are underrated). The box was about 3-4 cubes so it wasn't small. I checked the wiring and the subs were seeing 1 ohm from the amp. I've been feeding these subs this power for over 3 years and they finally blew last month, so I'm not disappointed in them they lasted a while.
Ok i see what your saying now, I didnt know you meant with an underpowered amp, i thought u still meant just by simply underpowering it. Calm now //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Well if they were getting that power in the right box I would expect them to last a looonnggg time, atleast if they were mine. Something was ****ed in your setup, most likely the settings on the amp or the quality of the custom box they were in.
:boobies: :boobies: :boobies:
:boobies: :boobies: :boobies: well here is a gift of good will. truce
IMXELITE
IMXELITE
PHILLY, PA
T3mpest
