What high / midrange speakers to get with setup?
  • 5
I don't have any plans of going that far, but thank yall for the info. It's good to know to kind of "future proof." If your running 4 18's on 30k watts and that speaker keeps up, wouldn't that be a little overkill if I'm only going 2 12's on 5k?
well you wont be running a 4 channel with bridged with 450 watts per 6.5 so it will be just right for your setup with the amount of power you plan on putting it on with just 145 watts per channel. Either way if you want to enjoy music, network mode is a must. If you just want weak sounding noise, then get a head unit without network mode and slap on a pair of components.
Well loud with good SQ, not just ear ripping loudness. What brand/model do you recommend?
i have some ******* prosound drivers that eat tge prosound drivers ***. i MIGHT sell them. I was going to use them but I just lost my I am and I'm not quite sure if I can get power to them they need about 200 per driver.
No actually built the sound extremely good and get Extremely Loud
i have some ******* prosound drivers that eat tge prosound drivers ***. i MIGHT sell them. I was going to use them but I just lost my I am and I'm not quite sure if I can get power to them they need about 200 per driver.No actually built the sound extremely good and get Extremely Loud
What kind? Theres some asterisks lol.
McCauley.com : Home
the 8" line array driver.
I just got home from a member here plug them up for about 15 minutes and realize that I might not be able to get a lot of power for him without going with a dirt cheap amp I had a hundred bucks to on them and it wasn't enough you need at least 200 by 2 more like three hundred by 2 but they're far far better than any PRO Sound mid-range you will buy without spending an arm and a leg and **** sure better than any car audio PRO Sound that sounds fantastic and they play well pass 1500 Hertz. I'm pondering on selling them selling them I'm not quite sure just yet but if you're interested I'll probably let them go and get something a tad more efficient
McCauley.com : Homethe 8" line array driver.
I have zero experience with home speakers in a car setting. do they work in a similar way or is there tweaking you have to do?
I didn't get a chance to run both of them yet I just mocked up mounting bracket in my door and tried one and in my amp decided to **** on me but I will say it is a PA driver it's not going to drop into the sub base I had across that 60 and then drop down low and it sounded extremely natural once I get I knew amps in I will give them both a try I just had to build some custom door panels and I've been working my *** off so I never really got around to putting but one in I'm just putting it out there just in case I decide to go with a more midbass dedicated type driver.
---------- Post added at 02:56 PM ---------- Previous post was at 02:55 PM ----------
By the way I've been building subs for about 5 years now and just started building my own mid ranges the picture you see next to my name is one of my mid ranges
I wouldn't lol. Car environments change things up a lot. A lot of the home speakers dont really work that well in a car environment unless you fully do acoustical treatments, not just deadening but wave, angle and reflection control as well, sometimes needing to make a dedicated fiberglass speaker pod to get a proper QTS enclosure to make the speaker perform right. They look good on paper and graphs but when you stick them in a car environment with just basic deadening and no other treatments, their performance gets fked up real bad. While car designed speakers look horrible on paper and graphs but when you stick them in a car environment, they measure up A LOT better.
this is a pa driver for line array. not home audio. fyi. and its far superior than those pvrs. trust me..
A car is a noisy environment, unless you completely deaden the whole cabin which involves mass loaded vinyl, close cell foam and deadener along with some reshaping of the vehicle dash, you arent gonna get the same performance as you would compared to a speaker in a dead silent house in a proper enclosure.
Tweeters are more forgiving but midranges that actually rely on airspace, arent.
I doubt it with with how inefficient they sound lol. My prvs get loud and sound great even at full range signal playing up to 12khz on head unit power capable of keeping up with a decent substage already with just 10 watts. They just become monsters when you throw ridiculous amounts of power onto them.
SQ in a proper QTS sealed or ported enclosure in a 3 way setup with dedicated midrange and tweeters, maybe, but in a car door in a 2 way setup, I highly doubt it.
Only real difference between most car audio loudspeakers and home audio loudspeakers are the suspension ones design for free air ones design for ported enclosures. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
exactly that makes a huge difference on actual performance, no one is gonna do a ported enclosure in a fking car door lol.
Yeah definitely way too much for me.
A lot of them are interchangeable though for instance a lot of people use these drivers which are primarily built for home audio and they do pretty decent in cars
so is it a good idea to hook midrange speakers on amplifiers where HPF has been set?
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
183
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
767
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
657
Snails
Snails
Ft. Walton Beach
Jcsaudio
    May 24, 2024
