Voltage on Headunit
  • 2
The gain setting on your amp is the only thing it will affect. No sonic differences; assuming you set your gain correctly. Lower preout voltage just means you have to set the gain on your amp higher (which could possibly cause noise...some amps are noisy with a high gain setting). Higher preout voltage just allows you to set the gain lower.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
634
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Geezersoup
Geezersoup
New York
Geezersoup
