Type R guru's ONLY please:
We will know by this weekend. I plan to listen to both and explain to all. Here's the two boxes I have and will swap the 12" subs back and forth:
- 1.1 cu ft sealed for the Type R
- 3.0 cu ft ported @ 28Hz designed/built by "MoeLester" for the HX2 last week.
Both tests will be done using an Eclipse 8454 and Diamond Audio D7401 amp (800x1).
do you have a meter? this could be interesting.
3 cubes is a little large for the 12", but it MIGHT work ok. Both subs are dual 4 ohm i'm assuming?
No, I don't have a meter on hand, but my local shop does. Anyways, I'm more interested in overall performance than just SPL, but we'll see.
Both are dual 4
I was told by the designer/builder of the ported 3 cu ft box that if I went with a different sub that could make it more peaky as mentioned.
02Corvette
LS1-1320 feet at a time
02Corvette
Houston, TX
02Corvette
