Type R guru's ONLY please:
"R" haters are welcome too...I got this (NIB) Type R sub so cheap (through a Best Buy employee that gets HUGE discounts) I might just go ahead and stick it in there to see just how loud it will go before it POPS //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif to see what all this talk is about!
you know you should try that. and see how far u get
3 cubes will most likely be too large for the 12" type-r. I'd say throw some solid objects (cinder blocks, scrap wood, etc.) in the box to knock the size down a bit and throw it in there for a quick listen.
It's not the most optimal testing solution, but it'll start to give you an idea. Type-r's are very potent woofers if put in the right enclosure and fed the power they need.
Someone had mentioned that the HX2 might get louder than the Type-R... This is FALSE.
I had a Type-R, and I blew it out of my own stupidity, but I have a HX2 in there now till I get my Type X, and the Type R was waaay louder, and cleaner than this HX2 could ever get.
Just my 2 cents.
Word!
Just my 2 cents.
Word!
Question, solved...thanks. Also what cu ft was your encloser?
Do you have some real world testing to prove otherwise?
That guy has owned and used both.....
Other than a vague impression of a customers Type-r and my old Hx2 nope. My install was a hell of a lot louder than his Type-r.
I was commenting on the install factor. Probably should have been a bit clearer for the type-r cult.
Generalizing that the type-r will always be louder than an Hx2 is false.
But has that guy used both in every emaginable situation? If no, then how can he say that the type R will ALWAYS be louder? Or better worded how can he say that the Hx2 getting louder then the R is false?
I can put a type R 12 in a 1cu.ft. sealed box with 1watt and have a pyramid 12 with 100 watts in its perfect ported box...would the pyramid have a chance to get louder? Yes. Therefor before you are so vague as to say that they type r will be louder every single time you need to get the facts strait.
02Corvette
LS1-1320 feet at a time
02Corvette
Houston, TX
02Corvette
