Featured Alpine Type S Enclosure Build
Qbenjamin
Need some assistance from the pros; I've done plenty of boxes in the past but never the actual design. I'm using the subbox pro website to create a small ported box for my R1T. As I'm designing the box, I'm trying to make sure this will work, as the negative offset of the sub has me questioning how this is going to sound (can't have the sub directly behind the port wall due to sub depth). Just trying to ensure this isn't going to sound like crap if/when I build it. Of course my other option is to do a front port, but I like the side port for venting purposes.
Appreciate the help, thx.
My current dimensions (inch): 32(W); 15(H); 7(D)
Alpine specs: https://manuals.alpine-usa.com/products/documents/IM_S-W8-12D2+4.pdf
Build Photo
  1. Not right now
Title Suggestions
  1. Not right now
Sometimes you don't know until you try. You can bend the port to make it front firing and move the location of the sub on the baffle if you want to shrink sub vs port distance.
Due to the amount of time and effort, I'd rather spend 95% of my time researching and the other 5% creating the enclosure. Hoping to get this right on the first try, it's not something I enjoy doing to begin with (building enclosures).
The cut sheet shows the right vertical port wall is only 4.25" in depth, so that won't work since the driver needs at least 4.5". This is why I moved the sub over to the left (-5 offset).
Quick and dirty with a little resizing using Torres note the overall size has changed and using a 3" round port 13" long should put it about 1ft3 net tuned 35hz or so.
1/2" materials correct?
Thanks for this and yes, I'm using 1/2" MDF since the Alpine is very light. I've never done a box with a round port, so this will definitely be something new for me.
Does it matter where the port is positioned on the right wall? Also, I noticed the depth/width is reversed in the sketchup, is that an issue?
Build it almost like you were about to but 27"w and side port the enclosure off center and I think you should be able to mount the sub to alleviate your original placement concerns.
Qbenjamin
Qbenjamin
Braavos
Qbenjamin
