Tweeter Spheres - pics and examples
ok but where do u get the spheres ?
michael's arts and crafts stores
michaels or hobby lobby or other craft stores carries them, as mentioned. a paddle bit can also make the hole you need. remember if you want to make a stepped hole - to start with the larger diameter then finish with the smaller diameter.
the real trick is figuring out aiming and the angle at which you should drill for the threaded rod - relative to the angle of the apillar.
i realized my angle is more than i intended, they will fire across more than i intended... so i may remake them. but for only a few hours - not a big loss. i'll run these for now. finish pics coming later tonight.
I used some rope caulk to temporarily hold the tweeters in place and also hold the grill on. i want to test before i make these permanant.
i'm also taking a different approach. instead of having the grill flush with the sphere, i have the actual tweeter cone flush and the grill protrudes - should be better, we'll see.
these vifa are tough since you have to make your own grill. normal tweeters are MUCH easier to finish off.
That... or we buy blocks of wood and whittle them down. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i have a plan to make large home audio spheres with the new Dayton full range or Fostex full range - i will make the sphere enclosures out of concentric rings of birch, so the inside is diffuse. then i need to finish the outside with either a router, sander, filler, or all of the above.
I think u have some business kha! Nice work man. I have only seen these utilized twice in many years and they both proved quite advantageous in both. Great thread starter
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
264
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
751
Tons of options in that budget, including the cost of installation,
10
814
It'll look like a "Hawaiian professional" did your install then 🤣
17
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
tat2bass
    May 16, 2024
    May 16, 2024
