trying to wire my door speakers to my amp? help.
Guinelle1
25
Chicago
Hey guys. newbie here.. im trying to wire my front door speakers to my amp but im having a problem. the amp is a rockford fosgate 201s and it works fine. so what i did was used JL audio speaker wire to rca adapters.
i hooked one up to the left front speaker output on my head unit, then ran an rca cable to my amp. hooked a speaker up to the channel output and all i get is a high pitch noise coming from the speaker. i messed with the settings on the amp but it doesnt do anything... can someone please help me?
I'm assuming you are using a factory headunit without RCA pre-outs. To use the speaker/high level output of your factory headunit with your amp you will need to use the high level input harness, connecting the high level signal to the RCA inputs won't work. If you don't have the harness for the amp you will need a line out converter.
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
567
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
Guinelle1
Guinelle1
Chicago
Guinelle1
    May 18, 2024
    May 18, 2024
