Trunk Rattle Questions
tribal16
I have a lot of trunk rattle. The guy at the audio shop told me if i took out my rear speakers and left them empty it would help(Lead straight to my trunk). so there would be 2 holes connecting my trunk and cabin together. sound waves would go through or something. Is this true? or made up?
Thanks!
Edit: Also is installing sound deadener hard? how much does it run?
most sound deadner is easy 2 apply just cut to whatever shape u need and peel the back off and use a roller and ur done. if u have hole in ur trunk lid u could use great stuff spray foam
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
831
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
tribal16
tribal16
Portland, OR
kgcolbyIII
