trouble tuning pioneer deh 80 prs
have slope on -12, sub is set to mono, usually turn up between 30-47 out of 62 have to turn the deh up more than any other head unit ive owned, im running a saz 1500 v.3 and im not sure if its just my amp not liking the higher voltage.
Are you running a mids/high amp? or is the HU powering your fronts?
The 80prs is safe to turn up to 52. The internal amp distorts around 52-54.
If you are running active. You can go up to 62.
I'd o-scope the sub amp. DMM's are just a guess.
Or borrow my DD-1 and set your gains with that.
Are you running a mids/high amp? or is the HU powering your fronts?The 80prs is safe to turn up to 52. The internal amp distorts around 52-54.
ive been trying to find a dd-1 in area just no resources. been posting rent a dd-1 signs around the city with no luck. atm im running all speakers off head unit sadly. looking for 4 channel but budget decides everything. what should i have my sub level set at if i were to turn it up louder ive been switching between -12 and -3 but cant get rid of muddy sound. think id have more luck setting sub level lower and turning head unit up more?
no. The level on your head unit should be 0. Just turn the gain down. And like I said. You can go to 52 safely on that HU without the internal amp distorting.
I live in WI and I rent my DD-1. I have an ad up in the classifieds.
http://www.caraudio.com/forums/miscellaneous-car-audio-classifieds/559026-smd-dd-1-smd-cc-1-rent-renting-out.html
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
913
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
972
Try tracking down your leak. Check your trunk, and around your antenna wire.
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
843
thatguy12
thatguy12
Madtown, WI
jockhater2
    May 12, 2024
Brendon Jenness
    May 11, 2024
