Thinking about switching things up.
Slobalt
I'm currently running what's in my sig. I'm pretty happy with it except the weight is killing me. I want to know what subs you guys would run trying to keep the weight to a minimum. This car is my daily and I plan on taking it to the strip once in a while, hence why I want to cut down on the weight.
What I've been thinking on the matter, first thing run 2-3 8's (thinking sa8 v3)Doesn't really work with the amount of port needed for them. So next thing, a pair of 10" sundown sd-3's in a sealed box. That's the only ideas I can really come up with. Lmk what you can come up with.
If money isn't an issue I have a Shocker neo sig 12" that would be good on a 2 ohm stable amp I'd sell. Otherwise try too find TC 3hp neo motor based driver. Significant weight savings over ceramic magnet drivers.
I was thinking neo but there aren't too many out right now (that I know of), I don't mind used but I'm not a fan of finding Waldo. How ever wouldn't go to another 12 because the box will be too big. Thank you for the offer tho
DD Z10!
Or ferrite the 3510
What's the weight of the sub/box? I'm estimating around 130lbs? Are you doing this for performance issues or gas mileage?
DD-Z, Warden, and Fi neos are all pretty heavy motors compared to the TC neos. You could likely save weight on the box by going with 1/2" birch ply with a lot of windowpane bracing and use sono tube for a port.
Alternate idea is if you can find some Aura "bass shaker" transducers and mount a couple to each seat, those plus a single 8" sub give the illusion of quite a bit of sub-stage.
Either up your budget or lower your expectations for output.
Budget meaning weight or money?
I was thinking maybe the xd series similar magnet size and same surround and voice coil 2.5
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
552
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
960
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
10
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
Slobalt
Slobalt
East Coast
MrFoca
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
