system ain't thumpin
what do
  • switch to spl sub
    Votes: 0 0.0%
  • bigger amp
    Votes: 0 0.0%
  • extra battery bank
    Votes: 0 0.0%
  • bigger sub
    Votes: 0 0.0%
  • Total voters
Turn of events. upon inspecting the sub with a multimeter it's a d1 sub. so it's wired at 2 ohm.
my question now: is running the saz 1500d at half ohm advisable or should I stick with it at 2 to be safe?
🍿 trade in that sub for a sub that has dual 2ohm voice coils? Buy a second identical sub and worry about your hearing when your 70? Run that beefcake at .5ohm!!!!
all viable options. appreciate the looking out.😎
I figured it wasn't at 1 ohm. A 15 inch sub ported on 1500 watts shouldn't lack output
That's what i'd do. Run at .5 ohms and just keep tabs on your voltage (make sure it doesn't drop too much).
I had a feeling I could run it, but wanted to run it by some more experienced people first. appreciate all the help guys. we figured out all the reasons why my 15" ain't thumping like my old 10".
srs: what's the worst that can happen?
you might try it like this. the correct test tones are at the very bottom...
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
107
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
596
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
682
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
minicorndog
CarAudio.com Recruit
minicorndog
California
Bobbytwonames
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
