suggestion on gettin a battery terminal??
Hurst421
I got 2 awg wire..15 ft long to go to my battery. DO i need to get a battery terminal i hook it up to the battry or can i just buy a ring for the end and crimp it on??? If so what size do i need and all.
Also waht is the differnec between a positve and a negative battery terminal (besides the obvious)??
"I got 2 awg wire..15 ft long to go to my battery. DO i need to get a battery terminal i hook it up to the battry or can i just buy a ring for the end and crimp it on??? If so what size do i need and all. "
You can get terminals that are made to support two seperate wires. They are more sturdy than a crimp ring.
"Also waht is the differnec between a positve and a negative battery terminal (besides the obvious)??"
I don't believe thatt there is a difference.
The positive and neg aren't the same
The negitive is made with a special metal element to stop alternator whine
no i'm just kidding ------------------ BUT they are different sizes.
I forget which but one battery post is slightly smaller than the other so that mean the clamps don't work on the wrong post
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
Your math might make a lot more sense when playing a Sin wave. Music doesn't draw near as much current. Hence why I was able to keep a 60amp fuse...
17
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
I had the Alpine version of those tweeter from years ago. Good tweeter, but some may find it a little soft sounding.
27
Hurst421
Hurst421
Hershey,PA
chris229
    May 24, 2024
