Suggestion for 6 1/2 rear...
cgraz1187
I have an 06 civic lx, everything is factory, 2 tweeters in the dash, 2 door, and two rear dash. The factory system isnt the greatest,I wont upgrade to a better deck being that my car needs a double din mount and they look very out of place. I want to upgrade the rear speakers and Im asking for suggesttions. Im trying to stay at $100 or less for the pair. Right now Im loking at the kicker 05KS60 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14834 ..
Im mainly look for better bass from the rear speakers, nothing extreme just a little bit more bass without adding a sub or component system.
there are quite a few threads and information about wether or not to use rear fill. It is a pretty hot topic around here... my opinion it is more personal taste, I feel there is a hole without it...and yes, I have invested a lot more money in to my front stage then I wanted to trying to accomplish the full effect I get by running a pair of mono speakers on my rear deck. DO NOT, and may I repeat, DO NOT put tweets or co-ax/component sets back there..you will totally ruin it.
If you only have room for a 6.5's in the back then just try to find a hard hitting mid somewhere. But if you have space for 6x9's get the JL VR's. The tweeter is very very weak and i play mine with an "All Pass" signal at 50HZ high pass. Sounds like there is a sub back there.
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
Your math might make a lot more sense when playing a Sin wave. Music doesn't draw near as much current. Hence why I was able to keep a 60amp fuse...
17
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
I had the Alpine version of those tweeter from years ago. Good tweeter, but some may find it a little soft sounding.
27
cgraz1187
cgraz1187
Scranton PA
zSnb
    Jun 1, 2024
    May 31, 2024
