sub placement in ported boxes?????
nauc
216
USA
does it matter where you put your sub, like this one is down and to the right, could you put it right in the middle of the box, cause some subs are more in the middle, some are off to one side
just wondering
example
it depends on the vehicle mostly. in your case it shouldn't matter that much.
closer to the edge is most likely less prone to panel vibration.
it depends on the vehicle mostly. in your case it shouldn't matter that much. closer to the edge is most likely less prone to panel vibration.
That last sentence doesn't not sound most likely to be less well understood:D
249
394
506
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
824
530
nauc
nauc
USA
bdawson72
    May 16, 2024
    May 16, 2024
