Sub not hitting lows, reccomendations?
dragonsho
Ok, so I have a Kicker S10L5 in a ported enclosure tuned at 38hz. Ever since I've had it it's refused to play lows (it's always been in the same enclosure). I was wondering if it had to do with the enclosure or just the sub itself.
An example is Flashing Lights by Kanye. The first bass line is ok, then the 2nd bass line (the lower one) just barely comes through and you just hear the kick drum.
Any suggestions of what is causing the problem? After reading some I believe it's the enclosure.
It's this enclosure btw http://cgi.ebay.com/10-VENTED-MDF-KICKER-L5-L7-SUB-ENCLOSURE-S10L5-S10L7_W0QQitemZ150251009756QQihZ005QQcategoryZ50568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ya that's exactly what I was thinking. Correct me if I'm wrong, but don't ported enclosures have trouble playing frequencies below what it's tuned at?
I think I'm going to try building a sealed box since I don't have much experience and then take it from there and see how I like that. Would you guys suggest using some heavy plywood like 5/8 in thick or should I use MDF?
What type of vehicle? Hatch, trunk? It's tuned way too high IMO, but have you tried moving the box around, or experimenting with different firing directions to see if your low-end improves?
My vote goes to enclosure, but you could be experiencing cancellation issues.
I have an '87 rx7 so I don't have that much room. I'm going to build a sealed enclosure that is in the kicker manual.
Front and back panel is going to be 12x12, top and bottom are going to be 12x10.5 and the sides are going to be 10.5x10.5
I would really like to be able to have a nice big ported enclosure, but until I get a new car, that's not gonna happen.
Thanks for the advice everyone, how do you think this box will sound?
Edit: Moving the box doesn't help, it's definitely tuned too high because some songs destroy the sub (A Milli by Lil Wayne). It's by far the hardest and loudest I've heard my sub go. It's just the lows.
dragonsho
dragonsho
boston
Safe_Cracker
