Sub half as loud in cold weather?
car batterys **** *** in the cold weather.
thats why they come with 2 ratings.
one of them is cca = cold cranking amps - wich are much less than the other one.
I believe that in cases of extreme cold - the battery has a harder time due to
slower re charge rate - and its psyical ability to give off power as fast as the amp wants it.
even if it rates 14v on a meter - it probly is not giving off as much amps as it would in 70deg outside weather.
in south FL where I live now - car batterys tend to die after 3 years due to low fluid levels in them as the hot as heck weather 24/7 down here evaporates them and exposes the plates.
- on a side note -
try hooking up a ok sized wire from negative battery terminal and running it all the way back to the negative on your amp. - this would test your ground circut in the cold weather, as it could be possible that its not as good as one would hope. - and at least rule it out as a possible cause of low output during cold weather.
i have good batteries and electrical. have noticed it seems a little bit quieter int he winter.
something i noticed is when its around freezing though, my batteries will show as high as 15.2v until the truck warms up.
i thinks thats becuase your motor revs higher when its cold to warm up, i have a cold air intake on my car and this howls like a mofo when its cold outside, 2min later shes back to normal ready to rock
i tryed to take a piss last night and it was 27 degrees, when i whipped it out i didn't have to piss anymore, instead it just shriveled up and told me to go back in the garage where it was a bit warmer.
//content.invisioncic.com/y282845/emoticons/ban.gif.ce8465566702ef9f72e97e794ed1c86a.gif
na, the rpm stays about the same. doesnt charge past 14.6 or so when its warmed up even if i rev the even and hold it there.
Maybe the alt is kicking out more to charge batteries that went down from sitting in the cold?
microhaxo
microhaxo
MINNESOTA
Notloud00
