Sub gauge Q.
Frankensuby
I'm in Ur F0rumZ
929
PA
I know that you can get away with thinner wire in a shorter run. My question is about whether or not 14 gauge should be able to hold 500 RMS @ 4-ohm load over a span of 5 feet or maybe a little less?
I'm pretty sure it can, but I prefer experience over assumptions.
~Levi
So far a 50/50 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I know 14 is good for roughly 750 watts (speaker wire) over I am assuming a 20 foot span (so says JohnEcon in the sticky up top)
I'll try it, if the wire melts...I have my answer //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
261
572
Frankensuby
I'm in Ur F0rumZ
Frankensuby
PA
Calikid
