dreamer
The distance between the face of the subwoofer box, and the back of the box, should be at least the distance of the mounting depth of the subwoofer. The subwoofer specs should give you the mounting depth. If not, simply measure how tall the sub is. Give yourself 1-2" of clearance at least. As for the distance from the edge of the box, to the mounting hole, that simply needs to be strong enough to support the subwoofer. I'd say give yourself a minimum of 2" each way for sufficient strength.
as far as a wedge box goes...
they are more difficult and time consuming, but obviously fit better in many situations. What you need to be able to do is cut wood at an angle. You can use a table saw, jig saw or a circular saw to do this. Cut along the line you want to cut.
To make wood on the angle side, that is more difficult. The only way I know how to do that is to make the table saw blade an angle and cut along the edge. You could just cut a peice of wood that is rectangular and slap it on, but you will have some overhanging lips.
