SQ HDC3 15 or FI SSD 15 in wall
Bjames0721
IL
I'm stuck between the SQ HDC3 15s and the FI SSD 15s. The build is going to be 4 15s walled. Its in a friend's vehicle and he is pretty much letting me do whatever I want. I can get each sub in about 4 cubes after all displacements maybe a little more. It will be powered with a single Arc 4k for now and possibly adding another one down the line. I'm looking for more of a demo over straight up numbers. Looking for clean lows. I have used different FI subs and I'm always happy with the results but since the cost is about the same after getting the options I want I have to consider the HDC3s. Any thoughts or comments to help me choose? Also, I'm open to other options if you have them. But i need to keep it around $1100 total for sub. Thanks in advance.
The HDC3 will shit all over the SSD, there really isn't any other way of putting it lol. The HDC3's can produce some serious output and they don't mind taking power either. I ran a HDC3 18 off an AQ2200 @ 0.5 daily for a few months and it took every bit of it just fine.
HDC3s. Have a pair of 18s a 7k(gains lowered), they take it fine and sound great. Before that had an hdc315 before that and that sounded way better and way louder than my old fiQ 15 ever could dream of.
I'm glad HDC3 is ahead I was wanting to try them out. My buddy knows I use FI a lot and he was pushing the SSD. I found some reviews saying the HD3s are "hollow" sounding and not very clean so that had me second guessing it. Since its one of my friend's I really wanted to give him the best I could.
this happens when tuned to its normal frequency at 38hz or higher.
It can produce lows.
On the 15's and 18's it reduces that hollow sound from what i noticed.
After reading your thread i have decided to get 4 hdc3 18's.
tune around 35 hz. A lot of people tune to 40hz with these subs because of the stiff suspension, it'll still reach the low notes if you do tune to 40hz but definitely sounds better being tuned a bit lower. However for your goals, go with a tantric sounds hd they are more clean low end SQ oriented while still getting loud, they cost a bit more than an hdc3.
If you like the Fi product, why not get a pair of 18" SP4's? They're only 500$ a whack and could certainly hang with 4K on the pair. You didn't mention the vehicle, but pair of 18's will be a lot easier to make sure you have adequate box and port volume and to have enough space on a flat baffle.
It is in a Monte Carlo. He wanted as much cone area as possible. Plus one of my old setups was 2 18 BTLs and I think he is wanting to do his own setup.
---------- Post added at 07:44 AM ---------- Previous post was at 07:43 AM ----------
Mattoon/Charleston Area. I'm sure we can do that. After all it is supposed to be for demos.
We will have to get together when they are done. Although, you will probably finish before me. What are you building?
Two DDZ's on a Taramps 20k amp
attachment.php
I'll PM you my number
Glad they stepped up and replaced it! I honestly would have thought it was super petty if they didn’t just swap it out for you still being under...
Buck has been my go to since I got into builds, currently he’s unavailable and hopefully back at his passion soon (for privacy I’ll leave it at...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
884
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
Bjames0721
Bjames0721
IL
Massive spl
    May 16, 2024
    May 16, 2024
