Speaker Rings/Apadters question
SpdDmn713
i am putting a set of 6.5 components in my front doors of my Tahoe and I know that i have to have some kind of adapter to go from the 5.25 stock speaker to my new 6.5. I had originally thought just to buy the little crappy plastic adapters but then decided to cut rings out of 1/2" mdf. Then while i was surfing around this morning I stumbled on these from Able Audio
http://www.able-audio.com/shop/product_info.php?cPath=21_22_39&products_id=28
I know that I sound like the stupid noob that I am, but I just wanted to make sure that these will clear up the space that i need. I am thinking that with the change in angle and that thickest part is 3/4" instead of 1/2" I should be fine. I just wanted to see if i could pick someone's brain that has used something like these as a size adapter before.
hell make ur own. I just made some 6.5s fit in where my 4x6s were so it can be done. just use the half in and it should raise it enough to where your magnet and all other diameters shouldnt matter since the hole before it was 5 in in diameter. unless u have beefed up 6.5s with a 5in diam magnet then ur ok. trust me it should work, and if not then whats a whole 10 minutes wasted making the rings instead of paying 18+ for somethin else you dont even know will work.
I had to do some cutting with the dremel but it was well worth it. go out and be a craftsman!!!!!!!!!!!
you can make it work but you'll need the spacer to come out far enough to where the speaker will fit in the hole. i imagine the magnet would fit in the hole, but the basket is probably gonna be larger then the hole
SpdDmn713
SpdDmn713
Atlanta, GA
FLOSSINON24S
