speaker hook up on a class d
35large
OR
hey guys, just found this site.. had a question I have a Hifonics XXZeus class D monoblock 1600rms at 1ohm.and a i have 2 4ohmdvc subs im trying to hook up one ohm... i just dont get why there are 2 pos. and 2 neg. terminals on this amp? which terminal or terminals should i use to get the max power out of this amp??
its cool...just wire each sub down to 2 ohms and then coneect 1 sub to each channel...that'll give you a one ohm load. There are two sets just to make wiring easier
comes with 2 sets so you can wire it how you would like. you can take and put one speaker say it has a 4 ohm load to one set. then take another speaker with a 4 ohm load to the other set. and the amp will parrallel the 2 loads for a single 2 ohm load. you can use both or just one set. up to you!
wire each sub like this
then connect each sub to one of the sets of terminals
35large
35large
OR
bonesninja
