macsdad
boom-boom
Any of you pukes seen the new amps over on sq's page. S1.2250 for 250. States that it can do 16volts, 2800wrms, 2300 at 14.4.
Can you state why? That's pretty typilca for most amps....power/ground together and remote in between.At least the remote connection is between the power and ground. I hate when power and ground connections are close together.
If I use dual 1/0 inputs I want them as far apart as possible. It's a piece of mind safety thing. The SQ 2200 has the remote on the side next to the outputs rather than in between power/ground.BigDWiz ooooooooooooooooooooooooooollldd school stereo............ dot com!!
---------- Post added at 12:43 AM ---------- Previous post was at 12:42 AM ----------
That's a good valid point...esp since mfgr's barely make the hole big enough to fit 4000+ strands of 1/0 inside. Wish they were oversized.If I use dual 1/0 inputs I want them as far apart as possible. It's a piece of mind safety thing. The SQ 2200 has the remote on the side next to the outputs rather than in between power/ground.
