Soundqubed amps
BigDWiz ooooooooooooooooooooooooooollldd school stereo............ dot com!!
---------- Post added at 12:43 AM ---------- Previous post was at 12:42 AM ----------
At least the remote connection is between the power and ground. I hate when power and ground connections are close together.
Can you state why? That's pretty typilca for most amps....power/ground together and remote in between.
If I use dual 1/0 inputs I want them as far apart as possible. It's a piece of mind safety thing. The SQ 2200 has the remote on the side next to the outputs rather than in between power/ground.
That's a good valid point...esp since mfgr's barely make the hole big enough to fit 4000+ strands of 1/0 inside. Wish they were oversized.
i hate it too. had to fab my own reducers to make it work for one of my amps. Had I used a typical reducer they would've been touching each other. Way too close to each other.
That is what GOD invented Dremel and sanding/cutting disc for. ;)
214
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
374
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
macsdad
boom-boom
macsdad
Trussville, Al
youdoofus
Brendon Jenness
    May 8, 2024
    May 8, 2024
