Smart3 on two L7 15s 12 qu.ft sealed running 4 ohms.
Probably not. If you get a dud it'll fail regardless of what you do with it and if you get a good one you should get your money's worth out of it before it dies.
You could very easily cut a large round port into that box and test a few different tunings, you can always plug it and seal it up again if you don't like.
Slo_ride didn't say that
here's something for you to actually experience what slightly deep bass is in the 30ish hz range, the one thats probably the loudest for you is the 39hz, kudos if you can actually play the 28hz with any kind of real authority in your sealed box.
I can't believe the L7 15 calls for anywhere between 1.75 cubes and 6 cubes sealed lol. Thats crazy.
I dont know that I would run a box that big if you are playing metal. I may go a bit smaller if you are set on going sealed. However, with a sealed alignment you are going to want to run at 1 ohm. Get as much power as you can out of the amp.
According to the Taramps site, there are three variants: TARAMPS SMART3 BASS 1 CHANNEL 3000 WATTS RMS 0.5 ~ 2 OHMS CAR AUDIO AMPLIFIER. TARAMPS...
Yeah if you want to be loud and don't mind losing the back seat start looking into building a wall. B pillar wall. Gives you lots of room for...
861
I don't know, maybe two 12's and two 15s on a IB wall maybe? Lol!
771
You may need to go to some shows and sound offs/meetings
GTSQ
CarAudio.com Recruit
GTSQ
Idaho
The_Grimy_One
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
