Setup help, Is my amp Focked?
85Caprice4d
I have a 10" JL audio sub im trying to run on an old boss amp. When everythings hjooked up, the ampe gets power but the sub stays off. I have the sub bridged in wiring, and Im not sure if that is right as I know nothing of ohms and such.
The amp is 150w x2ch and it is 2ohm stable if it helps and it looks like this;
Also, it confuses me because sometimes if i twist the RCA cables or just move it around where it is connected to the amp, I get a pop or a short low note. I thought it was the cables, so I bought new ones (same problem after), and then i checked the inner connections and everything LOOKED fine......
I just want to know if the problem is with the amp. I know its not the sub, becasue if i hook the sub up to my home stereo it will play without the amp, so it is either wiring or the amp.
edit:/// cmon if anyone knows how to fix it, otherwise i gotta find a new amp :-( and im broke
Completely hook up that POS and maybe it will work for ya.
Connect the + to your fused battery wire
Connect the - to your vehicle chasis for a ground (Scrape the paint off first for a clean ground)
Connect the remote wire from your H/U to your amp, in the appropriate slot.
I have everything hooked up right, im running off of a battery in my room to test it, i have pos run to pos on batt, remote loops to pos, ground goes to neg on batt...what could be wrong?
I have the sub wired on the "bridged" part, and i have pos on speaker to pos neg to neg, and i tried wireing it, + to + to + and - - - the bridge looping system:graduate: , nothing is working...//content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
yes boss sucks...it was free, unless u wanna send me a free amp i guess im good haha....//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif :greedy: //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
85Caprice4d
85Caprice4d
Milwauke, WI
85Caprice4d
michigan born
    May 14, 2026
michigan born
    May 14, 2026
