Settings help w/Pioneer DEH-X6600BT and existing Infinity Sound
Forgive me for asking a question that has probably been answered before but I searched and didn't really find the answer I was looking for. I recently installed a Pioneer DEH-X6600BT in my Dodge Ram 1500 Quad Cab that had an existing factory amp and Infinity Sound System and needed help understanding the need or not of the LOUDNESS and HPF settings. I do NOT have a subwoofer setup yet and from what I understand the front door speakers are strictly for bass so do these settings pertain to my system that has no sub? I know some of this depends on personal preference and I have played with the settings and found that the LOUDNESS set on MED or HI sounds better and the HPF changes the sound also although not as dramatic as the LOUDNESS. Thanks in advance! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
HPF means low frequencies are cut out of the speakers. If it's set to 100 Hz that means it rolls off the bass around 100 Hz. This should be left off, or to pass all frequencies, until you add a subwoofer.
Loudness usually means low and high frequencies are boosted. It's meant to be used at low volume so the sound isn't thin and weak. It's NOT meant to be left on permanently.
Thanks, it's just strange how much more powerful it sounds with the LOUDNESS set to MED or HIGH and the HPF around 80 or 100 although the bass does thin out the higher the HPF goes and vocals start sounding "tinny".
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
set your gain right, heres how. test tones are at the very bottom...
You will need a multi-meter, a set of RCAs that will be sacrificed, and a small blade screwdriver. First disconnect the amp from the LC2i. Now cut...
Hi, I'm new here and the current car audio that I've had for a month is my first in my life, so I'm asking for your understanding 😉 I'm starting...
Thanks for the info, made the setting changes and that did the trick. Toyed with the amp gain to get the amplitude balanced out, then tweaked...
Jeff Backlund
Jeff Backlund
United States
Side Show
