Setting my gain but cant get high enough voltage?
Yeah, Pioneer is a little ambitious on their pre-out volts... but I haven't had any trouble setting mine. It's one of the Premier line, with "4-volt" pre-outs.
46 / 62 on volume knob... no EQ ... and 1/3 to 1/2 gain, is enough to get full power from the amp.
Interestingly enough, their 4V pre-outs give me around 0.5 V AC on the ole voltmeter, at this volume. I'd like to find out if they will pump out the full 4V at 62 / 62. Most likely it's not for the full range of frequencies, and not continuous, but should get close.
According to DBfan187:
... I've used oscope on several models and they all clip at full volume, 61 is the highest unclipped volume level.
So set your gains on 61/62
you're setting your gain with the head unit volume too low. I'd raise the volume up a little on the head unit to see if this alleviates the issue. Also, you may have to turn the sub up to +6 in the crossover settings to get full voltage from the preout.
HannaS10
HannaS10
Ohio
boogeyman
