Setting gain with DMM
Ok did first test and was able to get the gain more then half way up on my 500 watt amp before I hit 31 volts
and this was with the sub settings turned to 5
If I turn my sub settings down to around 3 it goes all the way down to 20 volts. To get it back to 30 I need to move my 500 watt amps gain to around 3 quarters of the way up. Does this seem ok?
I am going to try it out this weekend, I hope the garage dont get too cold //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I cant even reach 30 volts if I have it turned to 0 even if I turn the amp gain all the way up.
Wth is up with that? This is suppose to be a 500 watt amp.
I set my sub to 5 on the head unit and got measured 31 AC
As long as I leave my sub setting at 5 I should be good right? 31 volts is a little under 250 RMS and my sub can only handle 250
0 db tones with bass is gonna be really light output use a 50 hz -6 or a 50 hz -10 if you listen to rock.
Cant I mess up my sub if I use a - tone?
Would the gains be set lower if I used a 50HZ tone? If so how do I know something like that wont come up in a song and make my amp go over 250 RMS then blow my sub?
u won't hurt the sub going over 250...unless u have one hela spike or clipping...
This is what my amp can do
125 watts RMS x 2 chan. @ 4-Ohm Stereo
250 watts RMS x 2 chan. @ 2-Ohm Stereo
500 watts MAX x 1 chan. @ 4-Ohm Bridged
I have it bridge because 250 watt RMS at 2 OHM would not he enough to power a 250 watt RMS sub at 4 Ohms right?
correct...with that hardware, you would have to run the amp bridged at 4ohm... and turn the gains down...wait...that is 500 max? or 500 rms
Decado2
Decado2
West Virginia
luvinthebass
