***LOTS OF IMAGES***
PHONES AND SLOW COMPUTERS BEWARE!!
Fuse holder assembled
Fuse connector
#1 (Coming from power connection)
Appears to have discoloration inside of it (that maroon-ish/purple stuff inside.)
Fuse connector
#2 (Leading away from power connection towards the trunk.)
Ground cable! (No discoloration, no cracks/splits/nicks in the shielding.)
Power connection wire! This wire is "Brand X Soft Rubber 4 GA Primary Wire"
(Where Fuse connector
#1 was attached.)
Main power wire (Long stretch from Fuse connector
#2 to the trunk)
Shows discoloration(My guess is from the tape) and my finger nail is at the beginning of a slit.
Said slit doesn't go deep enough to touch wire from what I can see/feel.
Main power wire
Showing the same spot as above image.
Main power wire
Spot on left hasn't been shown, spot on right is from the two above images.
Main power wire
Shown is a slightly discolored area that is hard to see.
(No tape residue to cause the discoloration, seemingly this is discoloration inside the wire.)
Focus on the right end of the wire, then look towards the left.
The right is obviously blue, The middle and left parts appear blue-green-ish to my eye.
Main power wire
Same spot, moved slightly left.
Showing slight discoloration.
More pics in next post. Silly image limit...
