Rear fill gone, now a few questions.
  • 5
On axis just means the speaker is pointed at your head or as close as possible. Most tweeters/drivers perform best directly on axis and start to wane in wide-range FR the further off axis they go. Here's an example using the FR curve of the Vifa XT-25 ring radiator tweeter(courtesy of Madisound):
Axis response is color-coded, so the black line is directly on-axis, purple is 15 degrees off axis, and red is 30 or 45 degrees off axis. Obviously the more off axis you get, the more attenuated the upper range will be even though they all play consistenly until about 2K.
Ok. Thanks. So since my tweeters bounce off my windshield they'd be considered 90 degrees off axis? Or is it different when bouncing the sound is the idea in the first place?
Bouncing off the windshield is a different beast, entirely. To make things easy, it would be more of an on-axis setup, but I wouldn't recommend doing that since reflections are pretty much the source for all that sibilance and harshness we try to remove from our tweeters. If your new speakers come with an angle-mount cup, that'll mitigate a bunch of reflection issues. If you want to go hardcore, invest in a dashmat as well. The difference is pretty remarkable.
Interesting. My tweeters are just in the stock location. What's a dashmat? How much are they? And where do I buy one?
Mine are in the dash too and I had harshness. But I found that ALOT of attenuation and scooting back about 6" cleared it up. They sound great now
Edit: Setting the levels properly on the door speakers helped too.
[quote name='ciaonzo'] excursion and power handling relative to those frequencies. Add to that, power response (on and off axis), filter poles (shallow to steep), phase and time coherency [/QUOTE]
@ciaonzo; Would you mind explaining these concepts? Or post a few links? Would like to read up on some of this. Especially how excursion and power handling are related to frequencies, I'm not sure if I completely understand what your saying here.
I ended up going with the Infinity Reference 6.5 component set up front, and polk audio dB 522 coaxial set in the rear. All of them powered by a...
29
38
707
673
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
831
calebkhill
calebkhill
Phenix City, Alabama
calebkhill
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
