Problem with voltage
xpl0it
http://www.comp-hq.com/volt.3gp
Ok, that's just a clip of how bad my electrical system gets drained (gets worse in some instances) idling. I'm running an mtx 1501d off an optima yellow top, and stock alternator. I don't want my voltage to drop, so what's the cheapest, and best way to go about this. I was going to throw my original battery (pretty decent duralast) in the front and stick the optima in the back. I don't have the money to afford another optima at this moment. I was going to connect posi 2 posi, negi 2 negi and posi 2 amp, negi 2 chassis. Would this kill my alternator even more? A local shop said yes, my friend who ran a zapco 9.0 off 2 redtops (not isolated) and 2 DD 9512s said no. I have about a hundred dollars to spend, so I was just going to get some positive and negative battery terminals and throw that battery in the back. Thanks guys. Ohhh, i also took some pics with my cell phone of my ground to see if I should ground my amp better.
http://www.comp-hq.com/ground.jpg
Batteries don't create more/better voltage. Use bigger wire to your amp. Relocate your battery to the trunk. Do the big 3. Buy a new alt.
Get a bigger wire? I dunno if I can find something bigger than 0 gauge, lol. Anyways, I probably should get a new alternator but again I cannot afford it. So putting my other optima yellow top in the back won't help with the dimming and such? ****. I'd love to hear some input.
do the big 3 and if that dont fix it then you need a bigger alt. another battery will get oyu by till it gets drained low enough to start dimming the lights and then your alt will work overtime to charge both batts. Not to mention that since your batteries are different the internal resistance will kill them slowly over time. No isolater make sure the batts are the same model/brand.
I told you all the input you need....
You didn't specify wire size. Moving the battery to the rear of the car would only help if you're amps are getting poor voltage.
Save your pennies/lunch money. $300 comes faster than you'd think.
xpl0it
xpl0it
everywhere
xpl0it
