How to bridge a kenwood amp??need help
lionel2
PA
I need how to bridge my kenwood KAC-9102D...its 500w @ 4 ohm and i need to bridge it to get that 500w...the terminals are setup like this + + - - do i wire them to the 2 out side terminals..cause when i took off the wires to my sub box thats where they where and professional wired it up...i only have a neg and pos wire comming out of box..the manual is not very clear...thanks any info would help.
Hook ur speaker wire into the two that say bridged on them(it will the positive from one side and the negative from the other, and it will be labeled)...
And are you running one sub or what?
mine does not say that..its a 2005 model...but manual has it pictured like this..............speaker inputs
and on the left most terminal and 3rd form left they have a picture of 1 sub wired up L+R + - and its solid lines they have another 1 sub wired on the other terminals but its dashed lines
lionel2
lionel2
PA
lionel2
michigan born
    May 14, 2026
michigan born
    May 14, 2026
