power for ed kxs?
  • 5
Different color subs ? Don't think so.
As for amps, the Avionixx 400.2 would work nicely - 400 x 1 @ 4ohm is plenty of power. You'd need the DVC 4ohm version to wire to 4ohm.
Really, there are a ton of amps in this region of power. Maybe we can narrow it down with a budget.
- Steve
that means that i can run 200x2@2ohms right? and could i get a better amp for the price, cause i'm buying it for my friend and he wants more power than that
are they black?
The subs ? Yes ...
The amp ?
- Steve
Sure, either way you'd need the DVC 4ohm version to wire each one to 2ohm or both of them to 4ohm to run off of that amp.
200x2, 400x1, doesn't matter.
Better amp for $185 ... doubt it.
- Steve
soundstreams good, not as good as they were, but so are like half a dozen other manufacturers (i wont name names............................Rockford would be one //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif)
how does it compare against other amps, and would a visonik 500 HC be a better amp because i can get one of those for about $120 shipped
4 x 50W Rms @ 4 Ohm Stereo
4 x 90W Rms @ 2 Ohm Stereo
4 x 150W Rms @ 1 Ohm Stereo
4 x 175W Rms @ 0.5 Ohm Stereo
2 x 500W Rms @ 1 Ohm Bridged
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
419
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
672
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
486
missionpilot
missionpilot
Gulfport, MS
missionpilot
    May 24, 2024
    May 23, 2024
