Possibly starting my own line of woofers...
response plots
Very low Q on those.
Idea on that is to raise BL, Sens, and Transience as well as give it a dip in response to counter the spike created by Le so it plays flatter and more naturally with little to no eq. (something few places take into consideration) You can count on 1dB of spike near 2x Fs per 1mH of le, this sub has an le of 3.7, so in optimum enclosure it has 3.04dB of loss near the le spike freq's. Should be able to stay within .5dB of flat (except on nodes) from 30 to 70(maybe higher) Given it wont feel or sound like it thanks to its large Vas once port volume becomes charged and should allow some pull in the bottom octaves as well to ease the burden on the system to achieve tactility below 40Hz and give it an audibly flat response. At least thats my goal and I have had killer results with this theory with my current single low Q 8" setup.
Isd beta doesnt plot le spikes for anyone still worried over the dip lol.
Moved for convenience
Nope, no name picked as of yet, logo for shirts and packing I'm happy with though lol. Text anytime, if im asleep my ringer would be off so no worries.
As few subs as I will be bringing to the market, think I will just keep it simple. Audio Phill's - Audiophile 12, hits the mark and and is more than enough to get the point across lol.
Audio Phill is the way to go. I had time to scan the proposal I did for the logo. Here, the last one was taken with the phone on my camera.
If anyone can make this a digital image that I can edit attributes of, I will make it worth your while, I can probably do it from a reversed image, but I'm a lil worried about my pc's capabilities.
Will know something about shirts tomorrow, Plan to include one with each woofer, and sale a few.
If I can get my wood shop up and running again, I may be able to offer plug and play systems as well
I got the RGB part down to a science, but I need an inverted one (black logo/White Background) for rgb conversion for shirts.
The easiest way i can think of playing around with it would be vectorize the file and use a graphic software to mess with it.
Or ask the designer to reproduce the design in photoshop and send you the raw file.
Both would work.
Sorry Phil. Actually I can do the black on white but I have to touch up the original image first and re-scan it. There are minor imperfections and detail my scanner has been unable to pick up. The style I used is loosely termed "drawing on the right side of the brain", a style I learned after reading a book by the same name. The negative as well as the positive values of space are uniformly complimentary of each-other, and equally important as separate values. In other words the space not used is also the part of the art. Now that I look at this I want to loop the ''L''s on Phil slightly, not sure why. I'll probably just add another line on the ''h'' on Phil. Get back to you in 2 days, busy. I wouldn't try and reverse this drawing btw, there are still amounts of subtle detail lost thanks to the scanner, have to make it darker. I don't know about t-shirts or stickers, personally I rather see wristbands the like of which can be found on jacvanek.com, but only because the material reminds me of the rubber slip on the motors like sundown and skar... That being said, I personally think that design would look good on rubber slip-cover of motors for subs released on a would be ''Audio Phill'' brand.
@audio_phill was this what you were trying to do?
Can't really say im happy about my work. Let me try and get it right 1st. Some lines are over emphasized just to pick up on what the scanner could not.
audio_phill
Walking TSP Encyclopedia
audio_phill
Small Town VA
Falcons
