Plans on new sub & amp combo, need advice
and to amp 2 ga is great size for all of it.. or u can do 0 to amp or 0 and 4 but lot of peeps use 2 for all.. i think it says it's good for 350 amps up to 50ft if so thats like 5k rms..
I think I'll go 2 gauge all around. Just so I'm clear is 2 gauge smaller than 0 gauge??
Sent from my SM-G930V using Tapatalk
yeah but like twice size of 4 ga.. look around for it boomintahoe uses it he has 2 2500 amps.. if u can't get it cheaper than the 0 ga get that (0ga can be pain to run to amp, some run it under car with garden hose to protect it)
Okay I'll look for 2 gauge wire
If you're getting a CAB... IDK why you'd use less than 0ga wire... the amp has 0ga power/ground inputs, the charging wire from alt to battery could be smaller (4ga) with a factory alt.
But the rest of the big 3 should stay 0ga
This'll let you do it once and correctly... if you upgrade your alt someday, all you'll need is to change the charge wire to sufficient guage.
And a 4ga charge wire is capable of supporting a pretty good sized alt anyways
Op... do it once and do it right, its not something you'll wanna redo.
Haywardr23
Castle Dale, utah
shredder2
michigan born
    May 14, 2026
michigan born
    May 14, 2026
