PioneerSPL1990 Alero Build Log
wow i havent posted in here in a while. well i just got some new toys. a kinetik HC1800, its not the same color but it is the same as the 2 KR2412's i already have in the trunk. next i purchased a poineer AVIC-D3 i have to brace it better and get the rest of the wires hooked up, but the music and Nav are working.
i cracked my bezel over the winter trying to put a changer in... ill get that glued today.
da.mn that looks good gonna be putting a a piller pod voltmeter in my friends car soon great work
thanks. sometime i have to pull the while thing off and wrap it in glass becouse when i got my windsheild replaced the friggers cracked it, but thats what i get for using all bondo for it.
Well today was a funnnn dayyyy bent over into the trunk i stripped the car out put in a peice of MDF FINALLY, anf redid my ground and added my 3rd battery, plus i did a cobbed battery holder, im going to redo it with 2x2's or 2x4's and pre-drill next time. I think ill be bringing another vehicle to the Vic Greene show to get some points in no wall,
the cars bangin' @ 50W Rms :lol:
stripped vvv
MDF in vvv
batteries in vvv
before i put the batteries in vvv
new ground, im going to unstack the blocks.
the bottom of the ground under the car.
im planning for at least 2 more HC1800's/KR2412's and possible a HC1200 under the hood.
YOUR BANK IS ONLY AS STRONG AS YOUR WEAKEST BATTERY.
OFF: My front one holds at 12.67V. The rear used to hold; when isolated at 13.86V with three batteries in its holding at 13.25V off, 14V on.
deconstructed my car heres the pictures of the process:
theres how it was when i hit my best 146.7dB at the windsheild sealed.
trunk board out.
stripped trunk.
stripping out the seals
box ready to be pulled out just have to take the door off.
the mess.
all done.
i got sick of my lack of bass, the mess in my trunk, amps sliding around and 2 of my speakers working so i mounted all my amps on a board and redid my Remote which has 6 different peices of wire, 4 different guages, and 6 splits. haha i also replaced one of my blown deck speakers with a matching spare i had.
then i put my cerwin vega in for some bass on my 500bd, i drove it for a day and had some dimming so i decided to put on of my kinetiks up front in accordance with woofercooker rules, and cleared it with Smithers and Wolcott. heres what i did.
thank god it changed to a CAI a few months ago or it would have never fit.
enough sewing i think i would feel safe cliff climbing with this.
Tight squeeze, i wrapped the entire ratchet in electrical tape lol i hit metal no matter how i moved it.
done. shimmed with a peice of MDF to keep the straps extra tight.
Starting fresh for 2010. I'm basically starting from scratch, back in November 2009 my ssXXX10000K burned up and i sold it off, i took a $550 loss. i traded 2 batteries away in stupidity, as is for my pioneer TS-W8102SPL and its backup.
This season I'm shooting for decent numbers, with great street-beat capabilities, I'm also moving into the trunk, hopefully doing some fiberglass work to seal off the trunk from the cab and give everything a nice finished look, final season goal is to have a second F2500D and a second TRF 12", also looking to do 4 matching batteries in the rear.
New equipment so far:
1 unused Rockford TRF 2212 thanks to OneBadMofo
1 unused Solid Audio F2500D thnaks to Infamous_e46
1 Used North star battery NSB100FT thanks to benzmansl65amg
Soon to have 140ft of 1/0 thanks to SPL Blazer
3/4" MDF, Loose weave, woven fiber, and resin are in the garage.
Box is going to be 15hx20dx28w tuned to 37.5Hz, going to do a lot of rounding and smoothing to bring the tuning up to around 42Hz
Pics of Equipment:
So far only $700 invested since 2010 //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
well i upgraded yet again, i picked up a bigger amp, a 15" sub, a new 4 channel amp, and a set of boston SX65 6.5's, i tossed the amp in last week and the sub in today. ill have to see what it'll do @ smithers on the first, i also tossed in a couple pics of the carnage the 5k did to the 12" trf.
carnage:
fixed not pretty but it stronger than before:
the new amp:
MMATS SQ4150 highs, TRF silver top 15":
p><p>
the beasts:
PioneerSPL1990
IM FER REAL!
PioneerSPL1990
Canton, New York
PioneerSPL1990
