Passive vs Active RCA Pre-Amp Level Controls
  • 4
mkzblah
I'm going to be installing a sub+amp but continue using my factory stereo. Since the stereo won't have independent controls for adjusting the volume / level of my subs, I am looking to get a remote RCA level control to throw up front. I have seen two options:
Passive:
Something like this ...
PAC LC1 - Amplifier (Bass / Level) Remotes - Sonic Electronix
Active:
JL Audio CL-RLC CleanSweep
I am NOT an audiophile, but I do like clean bass - one of the reasons I like the JLs. Is the JL active control worth the extra $$?
You could just use a line out convertor with adjustable gains if you are not trying to pay an arm and a leg. The JL cleansweep is pretty nice though. Its really up to you to decide if its worth the money. Other companies make good products for your purpose. I believe peripheral has some stock integration products.
If it were me I would go active. The passive level is just another obstacle in the signal chain. Then again so is the Cleansweep but at least the Clean sweep is active and has a line driver.
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
803
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Yep. It would be a little over 3 wired in series, but that’s fine.
864
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
mkzblah
mkzblah
Seattle, WA
Louisiana_CRX
Decebal
    Jun 10, 2024
