Particle board vs MDF
MerkConvoy501
Conway AR
So i went up to lowes to get some wood for my current box build.. And they had some particle board in the mdf wood spot.. So i built my box with particle board instead of mdf.. Im wondering what is the pros and cons of using the particle board i used.. I am aware that it will split easier then the mdf wood.. Im more curious of the sq and the durability of the particle board.. Thanks in advance
only a noob will ask this, well fisrt its not as sturdy, and most importantly its not dense... you want mdf because it makes the sub resonate inside the enclosure, and with particle board it has too many cracks where air can seep though and not give you the best from your sub/s
A big audio shop I worked at made most of its boxes from 3/4" particle board and never had a problem unless it got wet. Even some big boxes using w7's were fine in it. It's not as good as mdf but its fine to use IMO
And take a picture of it, might be mdf and the guy is just a tard
Well seeing that i got it out of the mdf pile i assumed that it was mdf.. But my installer at my job informed me that it was particle board..
I used to work in the luber department at home depot. People throw the wrong stuff in the wrong place all the time.
No particle board is pretty much the worst stuff you can use.
This is what happens when you have your sub mounted on particle board and you get rear ended at 50mph...
The screws rip right out and the sub comes flying at your head. Ya, it hurt.
Similar to the Power Acoustik A1800db / A2400db / a3000db / OV1-5500D amps, Planet Audio BB2400, Soundstream PCA2000d, and several others that use...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
MerkConvoy501
MerkConvoy501
Conway AR
keep_hope_alive
    May 20, 2024
    May 20, 2024
