Out with the old in with the new.
Update, got one of the t15001bdcps today.
[/img]
[/img]
what about the t3 audio t2000s?
and im going to build a different box and tune it differently, maybe put some type of quick connect/disconnects on the woofer wires so i can go from sq to spl, in under 10 minutes.
Why not just put a toggle switch in your dash (like your other knobs) for your sub amps so you can from spl to sq in one second lol
[/b]
I don't have the room for two woofer boxs lol, but if id did...hmmmmm
anyways got the t15001bdcp in, and this little thing is no joke.
[/img]
oh, that cap has two giant holes in it, and the dig display doesn't work otherwise i would have, lol
notice the electrical tape.......it covers the holes.
Update, haven't had time to really work since its 30 degrees, and i usually work/have class during daylight, and i don't have room in my garage right now. so this is what i got.
Sold the IVA-D106 and the imprint processor, and all the accessorys.
deciding between two stereos
A. [urlRL]="AVH-P6300BT"]AVH-P6300BT[/u
if i get this im going to get the fosgate 3sixty.3 processor when she comes out.
b. this is what im probally going to get want it so bad.
DEX-P99RS - Reference Series CD Tuner with Digital DSP and USB Port with Digital Direct Signal Transmission | Pioneer Electronics USA
but for now while im getting some of the other stuff im going to be rolling with this o_O
[/img]
[/img]
picked it up at walmart because the guy that owns a shop in town is a d bag and doesn't know sheet.
anyway it has a 3 band parametric eq, and its actually alot nicer than i expected, sounds pretty good.
one bad thing is that it only has two pre outs front and rear/woofer so i had to run some y adapters for my rear speakers, and use the rear out for my woofers.
also think im going to bust open the w7s instead of getting the btls.
reason: because of the roll over it has close to the same cone area as a 15, and it also has a higher x max.
since im so limited on space don't think that there is really a bigger woofer i can get with only 2k rms available per woofer.
How is the Rattle trap holding up?
this is my 3rd car using this in, and i always clean the surfaces really good.........as far as i can tell can't see a difference between this, and the dynamat i used.
never used a heat gun either.
kramer_212
kramer_212
Minnesota
kramer_212
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
